REW 5.20 beta 6
Re: REW 5.20 beta 4
#151 Messaggio da TomCapraro » 09/01/2019, 22:51
Bluenote ha scritto: Con che sw acquisisci ?
Ho utilizzato Adobe Audition, creando uno sweep lungo a 96khz.
Felix
Il mio Impianto: KEF LS50 Wireless+Sub XTZ 12.17+MacBook Pro 15'
Re: REW 5.20 beta 5
#152 Messaggio da Felix » 01/02/2019, 14:49
Altro aggiornamento:
V5.20 beta 5 changes:
Revised the EQ target setting panel to better explain the target types and separate the room curve controls, which can be separately enabled/disabled
Expanded EQ target selections, added a Driver target with LP and HP crossover filter selections, added a check box to enable/disable room curve settings
Added a "Speaker driver" target type with configurable low and high pass crossover filter responses
Added LP1 and HP1 filter types to the Generic equaliser to provide first order (6 dB/octave) LP and HP
Expanded the equaliser selection help to add a table of Q values to use with LPQ/HPQ filters to implement crossovers up to 8th order
Allow up to 8 subwoofers in the room simulator
Added a multitone decade fraction spacing option
Added a 1/48 octave option for multitone octave fraction spacing
Graph capture can now either save the image to file or copy it to the clipboard
Added a "Preview comment" button to the graph capture dialog
Step response calculation uses the windowed IR (including FDW if applied)
Main window comes to the front if a menu item is selected
Waterfall frequency resolution figure (to right of window width control) now takes into account the rise time
Window width, rise time and frequency resolution of the waterfall now appear in the top right corner of the plot
Do not show the distortion low pass/high pass overlay shading on the RTA when using dual tone or multitone test signals as they do not apply
Added a workaround for a Windows Java bug preventing proper display of Chinese characters in Audio device names, should also help with other non-latin character sets
If a recognised USB mic is selected as the input device automatically select the input as well so that the volume control is accessible
Removed -100 dB lower limit for magnitude values in imported responses
Reference input selector is shown on the Measure dialog when measuring impedance
Secondary output selector is not shown on the Measure dialog when measuring impedance when using ASIO
Use 4 decimal places on Distortion graph for distortion values below 0.01 %
Added support for importing COMSOL impulse response text files
Set default for the "Allow 96 PPO log spacing" analysis preference to be selected for new installations to reduce memory use and file size
Further reductions in memory use
Changed the installer application name from Room EQ Wizard to REW, affects the program group name and the shortcut name
Bug fix: Check levels could fail on the Measure dialog for some sweep frequency spans
Bug fix: Results of trace arithmetic on imported audio data would not generate waterfalls or spectrograms
Bug fix: Prevent multiple prompts for "Assuming a UMIK" when using ASIO4All and a UMIK is connected but it doesn't appear in the list of ASIO4All inputs
Bug fix: Maximum end frequency for sweep was not initialised correctly when Measure dialog was first shown
Bug fix: Spectrogram plot start frequency took account of lowest valid frequency for windowed IR instead of depending only on spectrogram window
Bug fix: Previous sample rate was not restored on the next startup
Suono con mani e piedi...
Felix
Re: REW 5.20 beta 6
#153 Messaggio da Felix » 20/02/2019, 13:56
Uscita beta 6. Changelog nel post di apertura thread. ;)
Re: REW 5.20 beta 6
#154 Messaggio da TomCapraro » 28/03/2019, 18:07
V5.20 beta 7
Re: REW 5.20 beta 6
#155 Messaggio da TomCapraro » 12/04/2019, 14:55
V5.20 beta 8
• Don't show smoothing selection on captured graph images, any smoothing selected can be seen in the legend if included
• Improved positioning of data panels on captured graph images and reduced panel opacity
• Added an option to include date and time on graph captures
• Improved icon resolution on macOS retina displays
• Added a set of icons for the dark colour scheme
• Windows installers now provide an option to allow multiple instances
• Windows installers prompt to download a Java runtime during installation if one is not available rather than including it in the installer
• Updated to JRE 1.8.0 build 202
• Bug fix: Some Scope settings were difficult to read when using the dark background
• Bug fix: If the input device did not provide any data it could be difficult to quit the Measure dialog
• Bug fix: Timing offset controls were overlaid on RLeads control if timing mode was loopback before selecting Impedance measurement
• Bug fix: Timing offset controls were disabled when measuring from file
• Bug fix: Graph capture comments were not being wrapped properly
• Bug fix: Soundcard calibration result notes were missing
Bug fix: If FDW was enabled by default the cal files were not applied when the measurement was generated, but would be applied on any subsequent window application
Re: REW 5.20 beta 6
#156 Messaggio da TomCapraro » 30/10/2019, 17:52
Aggiornamento REW
REW Windows 64-bit installer V5.20 beta 27
Re: REW 5.20 beta 6
#157 Messaggio da TomCapraro » 12/11/2019, 18:02
REW V5.20 beta 28
Re: REW 5.20 beta 6
#158 Messaggio da TomCapraro » 04/01/2020, 18:07
REW V5.20 beta 30 Windows 64-bit
Add bookmark
Today at 4:54 PM
Changes in V5.20 beta 30:
Added options to step in frequency or level to the Stepped Sine dialog
Added a stability test for the stepped sine measurement to optimise speed
Added a distortion threshold beyond which stepped sine measurements will be stopped. Distortion must drop below the threshold to arm it.
Made the stepped sine dialog non-modal so RTA window remains accessible for graph adjustments, but RTA controls are disabled to avoid changes that would interfere with the measurement
Added a new method of RT60 calculation based on frequency domain processing and a graph "RT60 Decay" to show the results
Allow multiple Y axis unit types for all relevant graphs (dB SPL, dBFS, dBu, dBV, dBW, V, W)
Did away with the plot normalised option for distortion graphs, happens automatically if dBr or percent selected as Y axis
Changed SPL & Phase "Invert polarity" checkbox to a toggle button
Added filter order selection for the RT60 and Filtered IR graphs, default is 6th order, max is 48th (filters are Butterworth bandpass)
Added the equaliser sample rate in the heading of the equaliser selection panel
Set Storm Audio EQ lower frequency limit to 16 Hz
EQ panel waterfall colour scheme is only disabled if live waterfall updates are selected
To reduce the screen space used by the Waterfall controls the settings for the view and colour scheme have been moved to separate dialogs
To reduce the screen space used by the Spectrogram controls the settings for the colour scheme have been moved to a separate dialog
To reduce the screen space used by the All SPL controls the trace arithmetic controls and individual measurement actions have been moved to separate dialogs
To reduce the screen space used by the RTA controls the settings for distortion and view have been moved to separate dialogs
Removed the filtering controls from the Clarity graph, filter settings are controlled from the RT60 graph
Revised controls layout on several graphs
Added a coefficient format selection for the Generic equaliser Save filter coefficients action, with a choice of miniDSP or SigmaStudio formats
Bug fix: SPL & Phase graph trace offset and Add to data buttons were disabled for measurements without an impulse response
Bug fix: Align IR start button in All SPL graph controls was disabled after using it
Bug fix: Clock adjustment failed for new measurements
Bug fix: Cal file parsing could be confused by content in comments
Bug fix: The delay figure in the measurement notes for aligned measurements had the wrong sign
Bug fix: Selecting the custom range option for the pink or white random noise with both the low cut and high cut boxes not selected would cause an exception
Bug fix: An exception could occur if the file chooser file filter was set to "All files"
Re: REW 5.20 beta 6
#159 Messaggio da TomCapraro » 14/01/2020, 20:53
REW V5.20 beta 33 Windows 64-bit
Changes in V5.20 beta 33:
When multiple measurements are loaded load them as a set then select the last rather than adding and selecting each individually. This speeds up loading by not triggering calculations that may be required when a measurement is selected, for example generating a spectrogram when on the Spectrogram graph page
Suppress low quality RT60 decay results
Bug fix: Dragging wav files onto the RTA for processing was not working
Bug fix: Loading a file with multiple measurements while on the Spectrogram graph with the Wavelet spectrogram selected could result in an exception
Bug fix: Could not select the manual settings button on RT60 decay
Bug fix: Guard against out of range error when fetching harmonic phase during stepped sine measurement
