TEST: il terzo suono del Tartini..alle bassissime frequenze.
Re: TEST: il terzo suono del Tartini..alle bassissime freque
#11 Messaggio da TomCapraro »
ecco qui Organist ---> https://we.tl/hQuPShX4ox (i file sono nel web per una settimana)
Flavio
#12 Messaggio da Flavio »
Felix ha scritto:Tra l'altro questa è anche una fenomeno (chiamata in inglese "missing fundamental") che diversi produttori di piccoli diffusori usano per "estenderli in basso"
Traggo da WIki:
"The missing fundamental phenomenon is used electronically by some pro audio manufacturers to allow sound systems to seem to produce notes that are lower in pitch than they are capable of reproducing.[17] In a hardware effects unit or a software plugin, a crossover filter is set at a low frequency above which the sound system is capable of safely reproducing tones. Musical signal content above the high-pass part of the crossover filter is sent to the main output which is amplified by the sound system. Low frequency content below the low-pass part of the crossover filter is sent to a circuit where harmonics are synthesized above the low notes. The newly created harmonics are mixed back into the main output to create a perception of the filtered-out low notes.[18] Using a device with this synthetic process can reduce complaints from low frequency noise carrying through walls and it can be employed to reduce low frequency content in loud music that might otherwise vibrate and damage breakable valuables.[19]"
https://en.wikipedia.org/wiki/Missing_fundamental
Interessante, sei a conoscenza di qualche prodotto che utilizzi questo stratagemma?
Felix
#13 Messaggio da Felix »
Ho trovato solo un articolo un po' datato http://www.maxx.com/objects/PDF/Loudspe ... igh_BL.pdf
Semnbra che ad occuparsene sia la Maxx che tra le altre cose l'ha implementato in uno speaker portatile Cambridge Audio... http://www.maxx.com/cambridge-audio-minx-air/
Suono con mani e piedi...
#14 Messaggio da MarioBon »
Traggo da WIki:
"The missing fundamental phenomenon is used electronically by some pro audio manufacturers .....
Questi signori hanno brevettato un sistema che, aumentando la distorsione, induce alla ricostruzione della fondamentale mancante.
http://www.mariobon.com/Articoli_storic ... xxBass.pdf
Il tema è interessante per capire l'effetto (deleterio) della distorsione di sub armonica. In pratica, a differenza della distorsione armonica che genereta multipli della fondamentale tipo 2f, 3f ,4f,..., questa distorsione produce frequenze par a f/2, f/ 3, f/4 ecc. .
Purtroppo genera anche le armoniche quindi normalmente lo spettro di distorsione a 100 Hz è una roba tipo:
100 , 200, 300, 400, 500...
con la sub armonica diventa:
50, 100, 150, 200, 250, 300, 350,....
In pratica questa sequenza induce l'orecchio a rinforzare la fondamentale a 50 Hz (che non esiste).
La distorsione di sub armonica è tipica dei diaframmi poco rigidi (specie in gamma media).
Capita di trovare altoparlanti che sembrerebbero dover suonare bene ma poi in pratica suonano "male": è colpa della distorsione sub armonica e anche del metodoto di misura dlla distorsione armonica.
P.S. Colloms fa anche il giornalista (Stereophile) ed ha scritto pure dei libri:
http://www.mariobon.com/Libri/1991_High ... olloms.pdf
(questa è la quarta edizione ma esiste sicuramente la sesta).
Visitano il forum: Nessuno e 18 ospiti
